Metalchipper
- Scarab
- HO Impulse
I have a 2017 Scarab 165 HO with 17 hrs on it. I bought it a couple of months ago after it sat at the dealership for a year or more in the back of the lot. Someone stole the radio and speakers out of it and I guess there was a problem with replacing it because it sat for for a very long time untouched.
Anyway, when I got it I had to send it in to fix a relay that was in the O2 system after sitting so long. I was so happy to get it back and put some time on it. I live on a canal in south Florida so putting the boat in the water is easy to do.
But when I pulled the boat out I notice an unusual amount of water in the engine compartment. I put the boat back in the water the next day with the intent to keep a sharp eye on the water. Since the bilge pump is not working either, I was extra careful to watch the water level.
After a hour I pulled the boat out and there was about 5 gallons of water in the engine compartment already.
By leaving the plugs in, I am able to see the water leaking out in the impeller housing that looks like it could be a seal leak or even the gasket that seals the pump housing in the fiberglass hull.
Has anyone seen this problem before or do anyone have any ideas of anything else it could be. Also the warranty will run out at the end of the year, so I want to be sure that any repairs as a result of sitting so long are taken care of before it runs out.
Any help will be greatly appreciated, Thank you
Metalchipper
Metalchipper
