FunTech4Real
- 222SE
I'm pretty set on buying a Scarab 165 but I have a few questions:
- What is the minimum octane rating of the 300 HP engine? Is this is exact same 300 HP engine in seadoo jetskis? If so, it needs fuel that marinas around me don't carry so I wouldn't want this one
- What is the top speed of the 230 HP version? I'm assuming this one has a minimum octane rating of 89 or lower, which would be sufficient for me with the local marinas
- Its hard to find information about the bimini top. There appears to be two different versions, one for the wakeboard tower, and one if you don't have the wake tower. It looks like the version without the tower is a vastly superior bimini in terms of coverage area. Is this correct?
- Are the bimini tops (both versions) safe to use when riding at full speed (up to 57 MPH) ?
