Robert Sands
- Toronto Canada
- Scarab
- HO Impulse
Hi everyone, I hope you're all doing well.
I have been tossing around the idea of LED lights in the back of the boat and I stumbled across some drain plugs that you feed through the boat and connect to your electrical system. I was wondering if anyone had any thoughts on this? I think I might try it, but before I do I was wondering?
1. What's the thread type and size on our drain plugs?
2. The most important question. The plugs I want to use have a diameter of 2.25" and protrude 2.5" from the drain hole. Would this interfer with the boat's propulsion mechanism?
3. Is it possible to feed cables through the drain and back up into the boat where they are accessible? I'd hook them into the existing lighting wiring so they turn on and off at the switch.
Any info would be great. I'd go measure myself but I'm working on site and won't get home for another few week and wanted to order the plugs for when I got home if they would work. Thanks a lot.
Rob
Rob
