Alex L
- Long Beach Island, NJ
- Scarab
- HO Impulse
Once again, my boat is on the sideline (Scarab 195 HO). After a terrible summer last year due to multiple delays with getting parts and Marine max being busy, I basically missed the entire summer and didn't get the boat back until September. Had it out a few times on the local lake before winterizing it.
Now, I had the boat out 3 times this year and it was running great. Over this weekend I set in on an unfamiliar area, thought I checked the depth enough but either the depth changed or something was sucked up that was floating.
Any how, I hear something get ingested and shut it down immediately. However the damage is done. The boat cavititates upon acceleration. The impeller appears to be bent on the one fin and also looks like the wear ring has some damage. It also appears that there is now a gap in the sealant that is on the front of the wear ring? Could this be causing the cavitation? Do you guys agree with that? Ive been doing some research today and ask for your expertise as I am going to attempt repairs myself.
I was going to purchase 159mm impeller and wear ring? I believe this is the correct size for the 195 HO. Wheres the best place to purchase from? Only place I found was http://www.impellers.com/scarab.html
Do you guys think that should do the trick? It doesn't appear theres any other damage that I can see.
Any specific tools needed for this project that are out of the ordinary? Im pretty mechanically inclined, but just don't want to jump into something that I can't finish, but seems like its not too difficult of a project.
As always your help is greatly appreciated as I look to avoid the dealer and get back out on the water ASAP. Hopefully everyone else had a better MDW than I did.
