SCARAB 215 2018 reverse gate does't open
SebaPL
Scarab
215 ID
Hi all I have the problem the reverse flap does not open completely, the cable seems to be adjusted, IBR reset, calibration done but the flap does not latch, can someone help?
what does BUDS mean "eReverse Cable Adjustment ( disable/enable ) what is it for ?
I had a problem with the latch on my 2019 195. Opposite problem in that it wouldn't release so it couldn't go into reverse (or neutral). It had to be replaced. You might want to verify that the actual latch is functioning properly.
