jbenson.850
- Other
- NA
- Other
- NA
I finally got the time this weekend to get the boat ready to go for the summer. I just put a new battery in it and made sure it was charged fully. When I place the key in the ignition in the on position I get a Reverse Module Error and a fault code of U0410. I see the gates are in neutral, but the display shows forward and does not change with a change in position of the shifter from neutral, forward, or reverse. Lanyard is on the kill switch and the post is seated as far as it will go. When I pull the cord and replace it I can hear the relays(?) clicking in the engine compartment. Any ideas before I load this thing up and haul it to the shop and break out another thousand? Thanks for the help y’all.
