Scarab Bait Well Pump Power
Status
Not open for further replies.
Jcombs
Scarab
195 Open ID
Need help locating the power and ground wires that feed the ACC1 switch on a 18 Scarab 195. My Baitwell pump has seemed to quit working and when I turn the switch ACC1 switch on, the red light in the switch doesn’t light up either. I’ve swapped switches so I know the switch is good. Trying to pinpoint were the power is coming from so I can check all connections, grounds, etc. Cant find any blown fuses or tripped breakers. Also, it was working perfectly fine for 2 trips and then just quit. Thank in advance.
Status
