Scarab Dealers in Florida
Jeff Scott
Scarab
HO Impulse
What cities in Florida can I find a Scarab dealer?
Thanks. I tried this. Only dealer I see is in St Augustine. My boat is in Bell, FL And I'm tired of towing all the way over there. Got 37 hours on it and it needs to go back for service for the 5th time! Fault code port engine P0300 and 301. Just had the port engineer worked on last month for P013f.
What motors? The is multiple misfire and a mis on cylinder 1. Before trailing it up swap spark plugs. Could be a simple fix. There is also sometimes issues of condensation in the intercoolers and intake at long runs of sustained cruise RPM.
Don’t forget you can also take it to any dealer that services rotax , seedoo
