Scarab P0201, P0202, P0203 failure
dworopay
Scarab
255 ID
Hey all, I’ve got a 2019 Scarab 255 Wake (178 hours) with twin 300 hp Rotax engines, and the port motor is kicking me the injector failure codes. I had them cleaned and didn’t solve the issue. I’m currently looking for a bad ground and can’t find anything.
It cranks but won’t fire. If it’s the ECU, can I swap the one from the working motor to the non working one to check or is it more complicated than that? Thanks in advance for any help.
Hi dworopay,
Did you ever get this figured out? I just got my 2016 215 out of storage and have the exact same issue.
Thanks.
I have a mechanic working on it now. They checked everything and the motor is fine. He thinks it’s a locked up bearing in the jet pump assembly and nothing will spin. I’ll let you know when it’s sorted out.
It was a bad relay. I read somewhere that these fail frequently so I had a few on hand. Wish I had remembered that before spending a couple hours poking around the harness with the multi-meter last night. ?
in your first post, you said it cranks over fine. If it’s a bad bearing and everything was locked up, I wouldn’t think it would crank over fine.
