Joatmon
- Estero, FL
- Scarab
- 255 SE
Ok this is embarrassing because I have been boating for over 50 years, but I have an issue I do not understand.
My 255 25 footer is the largest and heaviest boat I have owned and I thought I knew how to put a boat on a trailer. No matter what I try I cannot get the bow to rest on the winch roller once pulled out of the water. When the boat is winched on the trailer the bow is tight against the roller, but the boat pulls back as I pull out of the water. The bow ends up three inches from resting on the roller. I have had the same issue on four different ramps with different angles and replaced the winch strap because I thought it was stretching. The boat is not sliding back on the bunks. I have tried putting the trailer further in the water and tried wetting the bunks and power driving to boat tight against the roller. Every time the bow is tight against the roller when in the water but then pulls away as I drive out of the water. I tried routing and tightening the strap above and below the roller.
I think the boat is rocking back to match the trailer angle therefore pulling the bow away from the roller. Just don't know what to do about it. Never experienced this before.
Any suggestions?
Any suggestions?
