Scarab trailer
Master
New Braunfels, TX
Scarab
HO Impulse
Who is the manufacturer of our trailers? Looks like I have some scoring on my rotors, is this normal? I doesn't bind and It seems to trailer ok.
Not sure who manufactures them. I have problems with mine as well.
Manufacturer info should be on ID plate on inside of trailer frame. Looks much like the trailer under my Four Winns, and both makers are now in the Beneteau Group. (I also had problems- steel at the joint between the step pad and fender split and had to be welded). I think Four Winns had them under the Sure Load name. Can't check because I sold the boat.
