tdonoughue
- The Woodlands, TX 77381
I bought the Attwood 66553-3, like everyone else. Amazon. I steeled myself because this is a notoriously difficult job. I brought my tools:
(the thing that looks like a scupper wrench is in the plumbing section--it is used on slip joints, but it looked like it would be helpful here)
Before I started, which I figured would mean pulling off the plate by the cleanout ports, I pulled the little access plate to survey the situation:
OMG! It is right there! I probably don't even need to pull the plate (and, in fact, I did not). Unscrewed the clamp and removed the hose.
Used the slip joint wrench to unscrew the old scupper nut about 1/8 turn. The rest I did by hand. Easy peasy. Had been concerned as the new one was so long...
But, plenty of room there. I test fit the new one to be sure:
Yep, no worries. So I gummed it up with 4200 (not without its fun, the tube I had was a little dried out. there was wet stuff in there, so I improvised to get it out with my Philips head screwdriver--note the hole in the tube)
Had plenty of 4200 on there...
Tightened up with the slip joint wrench. Once the scupper started turning a bit, I used the large channel locks to hold the back side of the scupper while I tightened the nut with the slip joint wrench. Required a little gymnastics crossing hands through the channel lock handles to reach the wrench, but very doable.
Attached the hose and the clamp (getting the clamp tightened again was probably the most difficult part).
I think I was done in 20 minutes.
