Sea dek installed
Love it! Installed it on my last boat and really liked it. Will more than likely install on this one once I get all my other mods and fixes completed
Mods are alwayz fun!! ...and expensive!!
Love the sticker, where did you get it?
I had it made by some on-line decal company shortly after I bought the boat..wish I could remember the name because they did a good job and it has held up well... If I come across the name of company I will let you know.
Note to anyone that bought the cockpit kit and have not installed it yet. The two pieces that go over the battery compartment and the live well are easily swapped, the numbers had fallen off mine and i got them reversed. It's probably not noticeable to most people but i will kick myself every time I look at it......oh well. Should have pictures up in a couple of weeks when i finish the install along with Axiom 9 with RV-100 transom mount transducer. I machined a block of Delrin to mount it on. Will post dimensions once i know it works
NICE WORK....it makes suck a difference
Agreed, nice sticker. Still no luck remembering where you ordered it?
Did you all have the SeaDek installed professionally or did you do it yourself? I’m going to buy the kit just wondering about the installation. It’s been suggested to have it professionally done.
I did mine and had no issues, you just have to make sure the surface area is cleaned with acetone. The prep was much more work than the actual application. I'm not sure I would trust some lot boy at the dealer to install it on my boat
Agreed, do it yourself. I'm not terribly handy, and was able to do all the optional pads, no issues.
