Marco Racing
- SeaDoo
- Speedster
- NA
Hi. I have a problem with a 2005 Sea Doo speedster. I connected a CanDoo Pro on it and relieved the fuel pressure. I activated fuel pressure relieve. Then as it told me, I cranked the motor, took the key off and it said the fuel pump will be reactivated in 120 seconds and it started to count down. When it finished the down count, the pump did not reactivate again. The engine doesn't want to start again and my fuel pump also refuses to start again. It only cranks over. At the bottom of the Candoo screen it now says that it is in drowned mode. How do I get it out of drown mode again or how can I reactivate the pump again? The ECM is stuck in this mode now. If
