Sea Ray F 16
Bob J
SeaRay
Hi there I have a Sea Ray F 16 with a 120 sport Jet my power head I am told is not rebuild-able
does anyone know if I can replace the 4 cyl 120 with a V 6 175 200 225 or 250??
I am sure its doable however maybe cost prohibitive
thanks in advance for any suggestions
Bob J
I have no idea if a v6 would bolt up to your lower unit. But even if it did it would likely be cost prohibitive as you said due to all the other bits and pieces that would likely be needed.
The bigger question I would have is why isn’t your engine rebuildable? Parts are available and these two stroke things aren’t that complex.
I will Look into the Why thanks for your input
