heelsandracing
- SeaDoo
- Switch
Today was the first day of the season we took our Seadoo Switch out. The battery has been on a maintainer from winterization. We reinstalled it following the owner manual. We tested the electronics before heading out and started the engine very briefly to make sure all was good. After being out on the water driving for a few minutes the check engine light came on. At first there were no codes. Eventually we found a PO136 code after being parked for a bit and restarting the engine. We moved locations and with the engine running also received a PO138 code. This code later disappeared once done for the day. Has anyone received this code? Can’t find it with a google search. We only have 9 hours on the boat. Hoping it is just a faulty error since the battery has been out since probably January.
