DutchBoy17
- Chesapeake Bay, MD
- SX
I don't post much, but I've learned a ton from this forum and hope this is a useful contribution.
Yesterday we took our SX190 out for the first time in our second season of boating. Season one was short because we bought the boat in September, and we only got out on the water a half-dozen times; it was mostly fun, but it was obvious I had a lot to learn, especially when it came to low-speed control and dealing with choppy water.
Yesterday was day one of season two, and it was a really satisfying day on the water. Some things that really helped: CJS Vipers, no-wake/cruise mode, and a better understanding of low-speed control techniques (thanks to lots of YouTube videos).
It's hard to know how much of it was the CJS and how much of it was more knowledge, but slow-speed control is definitely something worth investing in.
Things that really helped?
Back when I learned to ride motorcycles, a key strategy I learned was to adjust speed and position to separate my potential hazards in time and space, so I could manage them. Last season as I started to learn power boating I didn't know/appreciate how helpful it is to be out of "gear" and to position the jet first and then apply a power pulse to slow things down. Over the winter I think I got a better appreciation of how to adjust steering and power to sequence adjustments to speed and direction as a boating version of what I learning riding.
I can't quantify how much the CJS Viper helped, but it definitely seemed like our boat tracked better at slow speeds, yet cornered at speed as well as ever.
Anyway, I'm definitely going to continue to work on pointing the jet then bumping the power.
Hopefully this'll help other new SX190 owners.
- Slow speed
- No wake mode: you don't need a lot of power at low speeds; so I clicked + once or twice, and then focused on direction and "gear"
- Setting the steering based on where I was heading and what I wanted to do with the stern to change that
- "Bumping" the throttle control between neutral t0/from TDE/forward or reverse so I could apply short pulses of power when and where I (thought I) needed it
- Working the helm slower when under constant power to avoid overcorrecting and controlling course
- Cruising speed:
- Getting just on plane and then hitting cruise mode
- Using cruise mode to back off a bit and just stay on plane
- Quartering the waves; last season I hit too many of them at 90 degrees
- Using minor helm/cruise adjustments to deal with the occasional larger wave
- Last year, around the docks/ramp I'd try to use low power in forward and then stop momentum with a burst of reverse; I always felt like I things were moving too fast and it was hard to take stock and think through the next thing I needed to do
- Yesterday: neutral, decide what to do, set steering, "bump" into TDE/reverse, back to neutral, repeat
