It does slide up... kind of. Make sure it is not locked up and the adjustment screw/bolt is loose. Then just wiggle it up. I had the same struggle, was about to unbolt it from the floor when it finally just popped up.
The trick I found was to have it swiveled halfway between forward and facing port side. Everything loose and and lifts right off with little to no effort. Mine had a ton of water in it... guess it does not drain well.
