ralphsmithiii
- Tampa, FL
I'm looking for some input while I also wait to hear back from @Earmark Marine regarding his thoughts regarding my 2nd round (small) upgrade path.
In January I installed (upgrade from factory) 6-MX650's: 4 in the factory locations and two mid-cabin and 1 10" IB Sub installed in the battery compartment wall facing the port side compartment. All of it is powered by an MX8/800 amp where the 6 MX650's have their own channel and the sub is using the last two bridged to power it. So far, other than some more fine tuning it's a massive upgrade over the stock system especially while cruising.
With that, our boat is going to be used 99% of the time parked at sand bars or keys, cruising to different sites, maybe some scuba dives and to go out to places to eat. Yesterday was an awesome day to get out on the water (here in Tampa, Florida) and the wife and I hit up a local spot called Honeymoon Island near Clearwater Beach, Florida. It's a decent size spot and dog friendly.
I backed in fairly close, dropped anchor, jumped out and pulled the boat within a few feet of the island and threw up the rear achor (shore spike) and we camped there for about 4 hours with our dog. The one thing I was looking to test was the following:
1 - Could you hear the stereo from the transom
2 - Did it sound "decent" and not project too loud to annoy/disturb others within common sense reason
3 - How loud volume wise would I have to turn the system up in order to hear it form the transom
4 - Repeat steps 1-3 if we where to hang out within a few feet give or take to the rear or the boat, say, 3 feet of water maybe on some floats or pool noodles versus sitting on the transom itself
With that, here are my observations:
1 - Yes, you can hear it from the transom including the sub-woofer
2 - It sounded "OK" but nothing to write home about. It was a night and day difference if I jumped into the boat itself in terms of sheer volume and sound quality. That little step-over hump to the transom area + the design of the boat has a major impact on this. You could barely hear it 10ft away on the actual sand key so no issues there even if someone was camped on the beach next to us, which was the case.
3 - I had it cranked up to 85% on the Connext screen give or take. In essence that means it's not operating at any sort of efficient rate (my logical-sh thoughts) as I had to power it much higher to get a decent sound at the transom. Where the gains are currently, it sounded like a night club while parked at 85% volume (50% I think gains on the amp) to give you an idea.
4 - Because you could hear it barely on the sand key about 10ft away being 1-2 feet behind the boat was similar to what it sounded like while sitting in the transom seats. Nothing exciting but being the type of person I am, I'd like to have just better sound back there even while casually conversing, floating, etc...
So here's what I'm trying to determine and I know that's a long-winded wind-up to the pitch =)
For those of you that have transom speakers (say 6.5's or 7.7)'s, how does it sound sitting there or behind the boat in the water? Originally I thought I really wanted to buy a set of JL 8.8 towers and call it a day, I'd have to purchase a M4/400 amp as well. I'm fairly certain I'm not going to pick up water sports although I'm sure we'll play around with maybe some tube's on a rare random occasion.
You can put MX650's or MX770's out back but I'd still need to figure out the amps. I'm thinking about going this route as I'm assuming having the speakers right there on the transom, while parked, would provide an upgrade similar to adding cockpit speakers. What I'm really interested in, how does it sound behind the boat while in the water hanging out. I could run a part of 6.5 (not sure if 7.7's) on the current M8/800 and move the single sub to a mono amp. I'm thinking for this I dont need an "M" series amp (unless someone tells me a reason otherwise) and do a MX300/1 (still IPX7 rated) and would be installed next to the M8/800 using the 2nd set of RCAs.
Going this route I think I can turn down the overall system quite a bit (we where there for 4+ hours with no issues on batteries) and control the sub with a M-RBC-1. Originally I thought about created two "zones" using two JL knobs and turning down the gain remotely on the interior setup and using the second knob for the rear transoms (or towers if I went that route). However, to do that, I would need to get a separate amp for just the rears (so maybe 7.7's + new amp MX280 which can put out 140w x2 into 4 ohms + volume knob) would make the most sense. Therefor I could have two knobs by the context, 1 for the interior + sub, 1 for the rears only) and when its sand bar time, turn down interior, turn up rears?
Oh, other thing I have to consider is: cut the seat cushions (I have no issues but have to find out the cost). But, is that + new rear speakers + new amp getting close to a set of towers (enclosure, mounts, amp) or is there still a massive cost difference. I'm hoping to get these answers from Odin.
