Setting the Clock
Chris Bortis
Scarab
HO Impulse
Sounds like a stupid question but how do you adjust the clock? I can access the clock on my display but can't adjust the time. Any help would be great.
2017 Scarab 195 Impulse HO
Good question!
Push mode repeatedly till you see settings, push set you will see clock, push set you will see clock offset. adjust up or down to correct time, push set.
