- Lake Ray Roberts, Texas
- Boatless
- NA
- Other
- NA
Have any of you ever moved or taken the slop out of your Shorelandr bow stop post? I had a chance to look it over pretty well and not by choice. I was installing a Stolz Bow Roller, and the stock Poly roller was literally crushed by the boat and scared up from the bow stop bolt. It appeared the roller or post was twisted and not straight on the centerline of the trailer. Now this can be a can of worms, because you just don't know if a bunk was installed off center, the post is off center, or the roller is off center, along with the bow roller frame maybe being off center. Anyway, as I was looking at it and trying to install the roller, I could not get the stolz center roller into the frame where the holes in it would align with with the two frame mount holes. Because the boat was loaded as it should be, against the roller, with the bow eye bolt snug against the stock roller, and had rubbed an indentation into the roller. So there was not enough room to get the new roller all the way back.
I decided I would just loosen the bow stop post and slide it forward, install the roller, and slide it back. Well, of course it wouldn't go all the way back. I am 1/2" from its original position. My intention was to move it into the original position yesterday at the ramp when we took the boat out the first time. But with a sailboat taking 30 minutes on the ramp, 2 pontoons, 3 fishing boats, and 2 other runabouts in front of me...and crosswinds and waves...and I had NO FENDERS! So I couldn't take time at the ramp to move it while it was slightly back on the trailer or tied to the dock.
Anyway, I have two questions for anyone that has messed with the post. Have you noticed that the post can be canted forward from pressure loading? There is room between the bolts that hold the post secure on the center rail and pinch the post mounting base along the rail. That room between the bolts and bottom of the rail allow the post to rock backwards and forwards. The slop has to go. I am looking for ways to do that. I think a sleeve or tube of appropriate thickness on each bolt between the base sides could take up some of that room, or a shim on top of the center rail or under it between it and the bolts. Ideas?
I also wonder if there is any harm in leaving the post where I moved it to. The boat is 1/2" forward and of course puts more weight on the tongue. Thoughts? I can move the post back to original position, I just couldn't do it yesterday. That winch is much more of a winch than the MFI had! But I notice the in several places, it says do not winch the boat up the bunks with it. I know why now, not because of the winch...because it will pivot the bow stop post backward on the center rail! Thoughts on leaving the post where it is?
