CDENsomnia
- Linwood, KS
- 242X E-Series
I wanted to post a heads up to those of you with a Shorlandr trailer. My trailer is about 4 years old and has been used quite a bit. It's mostly indoors but outdoors about 3 months out of the year. I noticed a broken bunk and so decided I should replace the bunks. At first I was just going to do the large front bunks because other than the broken bunk they seemed very solid. I decided since I had the boat off the trailer I should just do them all. Good thing I did because I found the bunks on the rear were rotten and since shorelandr used terrible hardware I found 4 screws on various bunks were broken off. Check your bolts on the bunks and feel the screws on the sides to see if they are in place. The one good thing about the design of the brackets that attach the bunks to the trailer is they cradle the wood. So even if a screw comes out the bunk should stay in place for a period of time. The first picture is the screw head on the top of the bracket and you can see it's missing from the hole.
