Alexegan88
- 252SE
We all know that we typically insert a Shorelander spindle sleeve at the most inner part of the spindle where the grease seal sits. Most of the youtube videos I can find show this being replaced when replacing the hub and involves using red locktight to bond it to the spindle.
However, a lot of folks upgrade to galvanized or SS hubs from other brands. I noticed the typical universal hub designed for #84 spindles (1-1/16 to 1-3/8 tapper) has an inner grease seal that's inner diameter (ID) is 1.719. This is smaller than the 1.741 ID on the grease seal found on the stock Shoreland'r hubs.
This lead's me to believe that Shoreland'r accounts for the sleeve by making the inner grease seal on their hubs slightly larger (as opposed to making that portion of the spindle smaller).
So now to my question. If I am using universal hubs with the smaller inner grease seal, do I really need to replace the spindle wear sleeve? Considering the outer diameter of the sleeve is actually 1.749 I'm surprised folks are not breaking the sleeve when putting on the smaller grease seals.
