bucks448
- Sarasota, FL
- SX
...to repair. They use custom parts that cannot be found anywhere other than from Shorelandr. This is my second time replacing leaf springs on one of their trailers (last time was on a LX2000)...this time they lasted 2yrs (I should have been more regular with the white lithium). Try finding 23" leaf springs anywhere. Also, they use metal bushings???, so even if you can get the rusted nut off, you have to cut the bolt (dumb).
This is what I'm working with...note how bass-ackward they put the u-bolts on. They should straddle the axle and be turn bolt side up, but instead they add a piece on top of the spring to keep the u-bolts from shifting.
