Shorland’r Trailer Hub Bearings
Bothomas
Hooper, UT
I know I’ve seen it but can’t find anywhere. Probably searching wrong words or something. Anyway, looking for information from those that carry a complete spare hub assembly. I want to get one for that insurance! Where can I get one that’s inexpensive?
thanks in advance.
They should be normal 3,500 lb. axles. Most likely 5 on 4.5” bolt pattern. Depending on which disc brake setup they use, the front and rear hubs could be the same, or different. (Some brake systems use slip-on rotors, others are integrated, meaning the hub and rotor are one piece). Hopefully someone who has one, and knows better which brake system is used. Or, just pop the wheel off your brake axle, and see if the rotor and hub are one piece, or two pieces.
