FSH 210 Sport
- Tranquility Base
- FSH Sport
A few things came together to bring you this story… first, my trusty grease gun was not so trusty after all. While it worked fine on my tractor pivots, bearing buddies and such, when it encountered restricted passages it felt the same as non restricted.
I went to grease the center pivot between the two axles the grease zerks on the pivot point between the two axles is on the bottom, which, will allow water to settle there.
In the past, I had greased this center pivot to excess and it made a mess, so going forward I would occasionally hit these grease points with a few pumps of the not so trusty grease gun assuming that grease was getting in there.
Yesterday I decided to make sure I was getting grease in there, and that is where the trouble began. It became clear that my grease gun was not pushing grease in there. Went and got another proper grease gun and attempted to put grease in and the handle was solid and wouldn’t move. I pulled the zerks out and found some crap in there, using the grease gun I cleared the zerks and put them back in but no joy. Pulled them out and took a seal pick and started digging around and pulled out a bunch of crap, followed by some Q tips, put the zerks back in and laid into the grease with everything I had and felt a pop and grease began to flow into the pivot.. what a pita!
Another thing that became apparent is that if grease does not get in there, and water will get in there and then sit on top of the zerk and nothing good comes of that. So my friends, be sure you give those zerks a shot of grease regularly !
