Markk
- Grand Prairie 75054
- Limited S
Anyone have sub enclosures in your boats that are working well?
My boat's previous owner left this box for me. He stripped the driver and amp, but left the box. I'm trying to decide what pieces to buy for my audio upgrade, but before I went with JL 10" IB mounted like most are doing I figured I'd load a driver in this box and see what it would do.
A couple notes on the box. It was stuffed under the port(passenger) seat on my 242LS. Driver faced rear and port fired up into fiberglass under seat. No port opening was made into cabin. Box was deskgned to split in half to fit down into cavity. Screws and sealed applied after in place.
I'm in the concert audio business so I have easy access to test parts. I loaded a 15" 500w driver in the box and wired it up to a crown ITEC amp for testing purposes. When the seat cushion above batteries was open the sub sounded pretty good. As soon as seat placed back the sub was greatly muted and rattled the boat chassis pretty bad.
I think the builder made his mistake in porting up straight into seat bottom. If he would have ported it to left or right and created an exit point to cabin it would probably perform much better. Since I have the parts I'm thinking of doing a test with port firing into open wall cavity and temporarily removing glove box to create an exit point.
Any thoughts on sub enclosures from the forum members who are in car/boat audio profession? Should I explore enclosures more, or just bail out to free air?
What enclosures are installed in your boats that you are happy with?
