- Northern Vermont Lake Champlain
- Boston Whaler
- Other
Since the upgrade, I have noticed quite a few unviewable signature pictures. I would like you all to see your stuff back. First you need to upload a Picture to the Media section here, this was my file info size it within the site recommendations, https://jetboaters.net/threads/sign...please-make-it-shorter-than-the-sidebar.3334/ then long hold on the address at the top of pic and select copy. Then go to your signature and select the picture tab and paste your address and then add the word "full" after the slash. This is what mine looked like before I hit INSERT. Thank to @MidnightRider for the tip a while back.
Without typing in "full" you will get an error that looks like this if you try to insert.
Note: I used these screenshots as examples. I left my Sigpic in tact for this thread and the two examples above were as if I were adding another one, just so I could show the message you get. If you don't add "full" you will not see the Sigpic and get an error.
