tdonoughue
- The Woodlands, TX 77381
So, it has not been that long since I pulled the pumps and, while they were out, recaulked everything with some nice silicone caulk. All the gaps, the hex bolts on the grate, etc. Maybe 3 years ago?
At any rate, took friends out yesterday, but we got there early as it seemed when we brought it in last that there was something stuck in one of the pumps when we came in. Got there early to check it out before everyone showed up. Turns out just found some dried foliage hanging from the grates (and no issue once we hit the water), but while digging around there to make sure everything was fine, I noticed that much of the silicone I had put on there is gone. Most of the gaps are all back. I think all but one or 1.5 of the hex bolts are uncovered again.
Not as effective/long-lasting as I had hoped.
So, then, to my materials-based question, please: What, exactly, are you using for resealing these gaps? Apparently my GE silicone caulk isn't the thing to use. Are people using 4200? Seemed a bit much to me originally, but given these results... Certainly don't want to do 5200 (what if I need to replace a grate or something?). Or something else? Thanks.
