Silverado back up camera screen to bright?
Brad_Ct
Alva Fl
I believe this applies to 2017 Silverados and newer. The backup camera screen at night was so bright I could not use the mirrors to back up and you cannot adjust it. After doing some research I found that there is a TSB 17-NA-269 that is a software upgrade. Had it done on Monday and it makes a huge difference.
My ‘17 GMC Sierra has same problem. However my ‘17 GMC Yukon dims correctly. I’ll ask the dealer about this ASAP.
2017+ Reverse Camera Dimmer Fix
I got tired of being blinded by the camera display being so bright backing out of garage in the morning. I ran across this, did it last night and it works great!
First remove the radio surround (the part that holds the heated/cooled seat switches if applicable) this has 8 Clips I think 2 above the radio and 2 below the ac controls then one on each corner. You can use tools to go from the corners or you can reach near the upfitter switches (park assist/adj pedals/traction control,etc.) find a edge or lip and pull upward firmly and evenly, some can be a real PITA but possible. Then slowly work around each clip the more you get the easier it gets.
Once the surround is removed unclip the heated seat switches if applicable then set the surround to the side.
Now to the radio LCD Panel, it has 4 bolts and 2 clips in the middle holding it in. remove the 4 bolts and start with the middle of either side of the panel (left or right) an again firmly but evenly pull out on one side once one side is out you can pull out the other side with ease.
Okay so now that the LCD panel is out you should see 2 plugs, one are the far right side(passenger side of screen) and one on the left (drivers side of screen) the left is a mini usb, the right is a 10 pin connector.
Go ahead and unclip both, no special tools required. Now move onto the 10 Pin plug. this is the hardest part of the whole thing, take out the white pin retaining clip (nmz787 used tweezers, I used 2 picks) once that is removed, lift up the black tab holding the pin in and remove the #3 pin, it SHOULD be a grey and green wire. The connector will show a 1 and a 5 on one side of the connector, in between that is the #3 pin. Remove it and tape it up good and re-insert the white pin retaining clip and plug both connectors back in.
That's it, Now time for reassembly. I'm not sure of the voltage inside of that LAN wire so make sure it's taped up and secured just for safe measure. (I taped the terminal and then taped it back against the harness out of the way.) (I don't recommend cutting it out just incase you need to return it to factory for whatever reason.)
Once that's secure place the LCD panel back in the clip slots and re-install the 4 bolts. Once those are secured replace the surround by first plugging in the seat switches if applicable then clipping the surround back in, then bam you're done and SHOULD have a fully dimmable reverse camera that follows the dimmer wheel
I saw that also but figured I would do the software upgrade first to see if it worked so I didn’t have to take the dash apart.
It's nice being able to dim it now with the "Fix". The only complaint I have now is how bad picture quality of the camera is, especially compared to my wife's same year Acadia
My '15 Sierra had the same problem. Dealer reflashed something or the other and it's better now. Still entirely too bright in just about every single instance, but that is a systemic problem, not just the backup camera.
