Simple modifications to Vortex
At the Sand Bar Again
Marblehead/Sandusky Bay, Ohio
Chaparral
VR
Hi all, I was never known to let well enough alone, so I made a few modifications to my Vortex. I have the 223, but from the gallery on the Chaparral website, most of these mods would likely apply to all models. I liked the results so I thought I'd post a few photos in the Media section.
(1) For the useless space to the right of the cupholder on the port side. I cut in, and added a SS pan for the cell phone, car keys, sun-block, etc. It was just a food prep warming pan. The size is "1/9". E-bay $10-12.
(2) I added a second set of bimini mounting brackets. Previously, the original location left the bimini top just floating and bouncing in front of the seats, which caused binding on the gelcoat and brackets. I didn't want to bother with patching the holes from the originals, so I just purchased another pair ($25-30) and added them about 5-6 inches back from the originals. This now allows the Bimini top (when down) to rest nicely on the area between the seats. Some days, we don't even put the bimini top up, which was impossible before. It also allows the Bimini to set on the windshield when I put on the mooring cover.
(3) Ladder modification. I was not a fan of the ladder protruding so far off the swim platform. We often hang out there with our feet in the water and it would likely get in the way. So when I ordered the boat, I specifically asked the dealer to provide the ladder "loose" and not mounted. I took it to a buddy of mine and had him machine some slots in place of the mounting holes. I used some nylon spacers and SS screws/washers to re-mount it. Now it slides flush when not in use, but extends perfectly when needed. The lid works just the same whether if in or out positions. I will admit, it was a challenge to install. I could have used a longer arm to reach all the way back into the recess to hold the nuts/washers when installing. About $25 labor & hardware.
(4) Fire Extinguisher mounting bracket. I was surprised the Chaparral did not come with a fire extinguisher and dedicated mounting location like my previous Yamaha did. I noticed some dead space in the port side"closet" just inside the door. I found by removing the filler board, I could easily mount one there. I used a hole saw a little larger than the OD of the F.E. and added some scrap Trex I had laying around. I used a double layer on the bottom, drilling the top one with the same hole saw. Slips in there perfectly and is very accessible if ever needed. No Cost.
Other than that, I just added some carpeting to the storage areas and rubber padding to the glove box and other cubby holes to pad cell phones etc.
I hope these tips work for you and improve your ride.
Let me know if you have any specific questions or need additional photos.
Good Luck
Those mods look nice. Well done.
Wonderful work. I really like #1 the pan on the port side. I'm surprised the fire extinguisher isn't standard. Mine came with one and it is mounted in the starboard under seat storage area. Maybe it was a option I choose, but I don't think so. Even though, I like your set up and bracket location for the extinguisher more. Really nice.
These look great. Been told I should get my boat this weekend, so once that happens I will have to look into these for mine as well.
Nice job. I really like #1. Question for you. Was there anything hidden in that area when you made the cut i.e. speaker wires, power cables to amp, etc...
Yes, there were some wires there, down below, but I didn't pay attention to what they were. They were in no way hindering adding the pan. I initially looked to just adding a second cup holder, so I removed the entire box (three screws), then figured a small pan would fit cell phones better.
To remove the grey box, you kind of have to raise up the existing cup holder and then bend the box a little to clear the padding on the top. It is ABS so pretty flexible.
I cut the hole in the box at the workbench, reinstalled, then siliconed in the stainless pan after re-installing.
For the life of me, I cannot figure out why Chaparral left that space open.
Maybe Chaparral did provide a fire extinguisher and the dealer removed it to "sell" it back to me.?.? I didn't buy it from him. I feel the new location would be more accessible in an emergency. Just around the corner and no bracket or latch to release. Just lift it right out. Like insurance, I hope I never need it.
I would be curious to see if you get a fire extinguisher.
I see your are from Evendale, my Daughter lives in Mt Lookout. Based on your location, I would assume you purchased through Hern Marine? We stopped in there last February when visiting our daughter. I told them I already purchased my boat up north, (and wouldn't be buying another one), but wanted to pick their brains and show my daughter since she hadn't see it. They were very nice and gave us the entire tour and for about an hour. Very nice people.
Good luck with your new boat.
Thanks for info I'm going to do this for sure. I did buy from Hern and so far really happy with them. They have my boat right now doing the 10 hr. service.
Well it only took forever to respond, but you will be happy to see my first mod completed...
First picture is in the port side storage - after I realized my multi-tool wasn't going to do what I needed. A quick Depot run and a 3 1/2 hole cutter for my drill and I was through it perfectly in 1 minute. Wrapped with some rubber window seal and the finished project. Not sure why that isn't standard. Seems too logical not to be.
Also - My boat did not come with a fire extinguisher.
