kgower
- Buford, GA
- 222SE
We have had continuous problems with water in our ski locker (21 195s). Spent the weekend adding second battery, battery switch and ACR (Blue Sea), Our driveway is sloped. When I went to test the bilge, it wouldn't come on. after having the hose running for a while no water was accumulating in the engine compartment, instead it was running straight into the ski locker. Not through the drain plug as it was closed. it ran straight under the lip and up through the ski locker whole. and seam. Hopefully a heavy silicone bead will do the trick.
