Ski locker
Hockeyguy1960
Woodstock Georgia
AR192
I’m wondering why I’m having issues with the ski locker draining on my 2015 Yamaha AR192…I keep the plug unhooked…I read that maybe I need to replace the seal on the door itself? Cause I do get some rain water in the boat from tears in the cover…I keep the boat in a slip in Georgia in summer time…should I replace that plug since it’s probably never been replaced? Or maybe ck my bilge pump operation? Any thoughts? Thanks
Are you saying it’s not draining?
If so, you also need to open the drain plug inside of the engine and fuel tank areas otherwise it won’t flow from ski locker. They’re all connected or at least they were on mine.
Yes I open the drain plugs on the transverse but I will look in the engine compartment as well thx!
