So I sold my Aquatrax.......
ScarabMike
Green Cove Springs, FL
And I purchased a slightly used RXPX 260. Took it out for a spin, and it started to take in water, and about rattled my teeth off.
Got towed back to shore, and saw what I was dreading from the very beginning. The bellows was leaking water due to a worn carbon seal. All this at 16 hours.
So, I politely took it back. It will teach me not to ever go against my intuition. The repair was going to be free because it was within the 12 months, but I decided to not even keep it. Now it will go to its third owner.. wow.
So, I finally got my first Yamaha!! Its sick. 2015 FZR!
Big Congrats, Mike !!!!!!!!!!!!!!
Great 'ski in
GEORGIA BULLDOG colors ! Gotta Love it !!!!!!!!!!!! LOL !
Sweet ride!!
Sweet ride!
At the 30 hour mark my Sea Doo did this as well. I fixed it $1000 later and kept it but felt the same way when I bought it that it was my biggest fear the stupid seal would go.
So I just installed a stereo on the waverunner, with an amp, and a cutoff switch. Sounds great, and finally able to ride with some tunes!!
Awesome! I NEED that.
Is your trim controlled with a twist grip @ScarabMike ??
So, @ScarabMike ...
Is that how your ski came stock? With the trim like that I mean? Mines got buttons.
Also, I don't see a lever on that side - no brake/reverse? Or do I just not see it?
That mount on your handlebar - I assume that's for GPS? Who makes the mount?
Speaker pods - who makes em? You happy with em?
You running an additional battery I assume? I assume that's what the switch is for above your amp?
I'm looking into amps and speaker pods for both skis (buying another ski soon). Gonna try to just run both amps off bluetooth, don't really need a radio. Maybe even run an aux cord into the glovebox. Wanna keep em both pretty simple and not go overboard like I did on the boat. Just need some sound out there.
Thanks! Sorry to bombard ya with questions, lol. Don't really hang out on any of the ski forums.
@veedubtek
Yea the FZR/FZS waverunners don't come with the fancy electronics. Its basically the race ski that Yamaha competes in the races with.
Yea, I have a reverse lever on the right side. Its not electronic.
The mount is made from RAM Mount. Its made for motorcycle brake reservoirs. You have to replace the bolts that come with it with some that are the same thread pitch as the stock ones, and a tad bit longer. I also used 1" aluminum sleeves to make the instal look OEM. Ill take a picture of the stuff when I get back home for you. Here is the link for the brake reservoir adaptor. You can custom build from that point using the 1" ball adaptors.
http://www.amazon.com/gp/product/B0012TT8BK?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00
Then you add an arm like this.
http://www.amazon.com/gp/product/B002L9LW00?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00
Then get a mount for your cell, gps, what ever....
http://www.amazon.com/Cradle-Holder..._UL160_SR160,160_&refRID=0Z3Y6D20BKJ1X53S2R3E
The speaker pods are actually 6 1/2"ski tower pods that I took the tube mounts off, drilled 2 additional holes, powdercoated them, and mounted them to the fairings with some aluminum reinforcement plates behind the plastic. Here is the link to the pods. Many vendors sell them, but just make sure the mounts are completely removable, and that they don't have the wire nuts on the outside.
http://www.ebay.com/itm/291419929931 < --- This vendor is awesome BTW.
I'm not running another battery, and the disconnect is just for the system (radio/amp). The radio has a low voltage warning and auto shutoff, but I wanted to have a physical disconnect. When you run the amp power, make sure you use nothing less than 6 gauge wire. The voltage drop is pretty bad from the rear to the front of the ski.
Also, I used a low amp draw amplifier. Its incredible. Dont use that Pyle, it sucks. Use this one. Its a class D full range amp, and it pushes the speakers loud enough that you can hear them while going full throttle.
http://www.amazon.com/dp/B003VVYL46...TF8&colid=367R8AA6E6GON&coliid=I2BMOFN7UYI0RT
If you dont want a radio, use this amp. Its very nice, and the bluetooth works great.
http://www.amazon.com/Kicker-40PXIB...=1446983880&sr=8-2&keywords=kicker+marine+amp
No problem man, you know me...... always brainstorming,lol.
Also, if you dont want to cut holes in your ski, or want to make the 6 1/2" speakers into subs, then add mids and highs with a crossover, check out this site.
http://www.soggydogaudio.com/
Kevin is great to deal with, and his products are awesome.
TYVM @ScarabMike !
After much engaging of the google, I've decided to go with those same cans and a Kenwood BT amp that seems to fit the bill nicely. By the time I get them, and also have them powdercoated, I should have the new ski and ready to install. And likely end up ordering the same for the current ski. I'd love a sub and mids and highs and all the volumes, but I'm really trying to keep it simple.
@ScarabMike that set up looks as good as the factory Kawasaki. Very nice job. Here was my music fix solution. I imagine it isn't as loud as your set up :)
Dryvibes wireless bluetooth. It's a pretty solid little speaker and I picked it up on sale for $35.
As always @ScarabMike ..... Great write up!
Thanks @Murf'n'surf !
I tried something more powerful and similar. Altec has a very nice speaker that mounts with the go pro mounts.. I couldn't hear a thing at idle.
hIDOKffXgCI0yGGqE_hYN9i1hM0PLptpqUUMssAJro10P8VolO5BAjpQvwLgwmQPxxVssMGKpa6Lo5c50U-kCt_ZtIHb051i-gwmctZ_eqUITS0BVh4WNuJW4H46CSwEt2_geGJGDycSeyccdGkEtWzAreBjhWLkvnUlo32S5sGOhDHNI1aVKVE4MqU39DErxo9HLRb27UcXyk6twVZiMaR_esuhXpPY4oTU-bRl-8FWFxOCfTiqctXmDZmUZ920PVzNjEoLNugK6q3SIpleukURtKvT06SC8-iSQi7plzBH7h8wwpZ4-3GATNuF-Kn2BVEz0RyzcWZ1jgn7g9f5eeY1KlXB1r-uf5dylnZDtarbgQK1PnoNxssa6u937VCHqDOpCOI3KtD8ax6iJnOpB92BpEbGsvGus2sp9fkbHoGRj1Q-6QQx0u6I4h0_SUBdTj7EhFhLJ4nSvj8_hLw_rM7Ts3HcTl_tCd1VYIdF5jPBXHplY-A79hPhLyT-f7AuHWSxeZuN4d4zum-oHeg3mJNnhwQ2-k6_NfdhTP8ghD8=w1252-h940-no
FlHdFtzA6YANN8V7RwHv-Q2YebkVdnADnIW2sozqyBPBikKOM_kH6peWCgrUD38z3AYm9D7_UkwSwXQOhwpdY4vhb3T26v9WfnOSlCzMVUIiVRQEBWQO4JBioSaIILMBn-7xoyDQGRU1DGNNDYS3X_PpKEYrqLz9nWVN7mi_D6j0WUxvU_V9HB5s_yk3ZODxMw0oyw4v9qwa5gPkx_LMRsK0Zn8BtQ_P-7kjTGDlSj94RYgntDiPVium-3EMuQuv-PVXh6yKtyftLLuqSiNzOkd1FEYAhF2ZAibHxZwePz7M2OdcFS5GLSmfrwO1PS4OUCtM2SC1Dw2vZonZOAyri00VF4Z98gKaMYPRdZ6loJ0GFKfsichhTtgsMsjyawr3kbHn-FkHhQrll9bTmZ0cmRkMUk9iIW40hbcP54sr1YFZxKaQbcFkJ8MBquMOsPI8uy-e29gety4GsuaXfz5FQi-9yJtIjMkgHJSrEl9F-9BaVMCiTK9GutY7AFkQjXdoKrv7tirMPcRzUgqvJfKWbRFFozBRwYiMGCRK4V5tefw=w705-h939-no
Oh no, listening while riding with the little dry vibes speaker is definitely not an option. It was basically for stops in the cove. Your ski looks fun...
