so uh...I broke something yesterday.
outch.....! Sorry about your situation, definitely makes a bad day. Did you hit something moving fast or moving slow while maneuvering? Quick call to the dealer to get a price on the bottom plate and rudder would be your cost?
no wake speed thru a random shallow patch we got hung up in.
everything still worked but at around 6k, the boat didn't come to plane and had a high, whinny sound.
anyone have a part number or link to the parts needed?
Steering Plate, Ride Plate I would look at partspak and iboats for other prices. When you got hung up were you reving the engine or did you get out and push. If you were using the engine I would venture to say you may have ingested rock, sand or other foreign objects into the intake.
I was deff. on throttle. I powered thru it and got out and continued on.
are you saying that because of my symptoms or from this damage?
Running these boats in shallow water can be hazardous to the impeller and intake system...even sand, silt, or mud can really wreak havoc...Here is a good THREAD to see what can happen and the repairs that may need to be done.
^ thanks. so my impeller is probably toast too.
that whine and lack of speed, is cavitation?
two things...
1. can running it like this at slow speeds for another day cause any further harm?
2. from the broken parts, what would I experience? steering issues or the symptoms I'm having? (ie: lack of high speed & whine)
also, from those 2 links, I'm not seeing the piece(s) that I had there.
I'm trying to reference old photos from when they were there.
this is a screen grab from a video I had in my phone. the piece looks like one long solid part:
IMHO the boat should not be run until you get a clearer idea of to what extent the possible damage has caused. I would start by sticking a flash light into the intake grate and doing a quick visual inspection of the impeller and liner, then proceeding with a tear down for my own piece of mind, before she would be put back in the water with other folks aboard, I would suggest pulling the nozzle forward and checking the liner, the impeller, etc. .
Which pieces in the links are you referring to? I will try and help you find them. I don't mean to sound so straight forward I empathise with you and hate that this happened but right now we just need to find the parts and get you back out on the water, safely and without doing further damage to a nice boat.
Here is a LINK to the 2018 service manual for the sections I put in the links. Hope it helps.
Yes that should be part#21 on the Jet Unit#3 link I sent earlier.
I'm no expert but the pics look to be fine maybe some wear marks in the impeller housing unit and light marks on the one blade of the impeller (at the 4 o'clock position) but from what I can see nothing to serious... :winkingthumbsup" , but I'm sure some of the folks who are far more intimately familiar with impellers will chime in to help also.
good looking! saved me about $200. I'm into like $850 in parts and should able to do this all myself easily...
I would say it would steer about the same at low speed since the Cobra's will be down. On plane, it will probably steer like the older Yamaha's without articulating keel. Luckily you have the Cobra Ultimate? that flip up when you hit something. If you had Viper like it do, you would probably be looking at more damage.
Being that the rudder is located beyond the intake and impeller, I see no reason why if would affect rpm or sound. Take a good look at the impeller and housing, which judging by the pictures you have. Maybe even pull the pump as suggested and investigate.
But...I wouldn't let a ripped off rudder ruin my weekend of fun. Not long ago, they didn't even have a rudder.
If the high whinny sound was immediately after getting out of the channel, perhaps something got hung up then got dislodged? Or did the sound continue till you got back to the dock? If you have the cobra fins, one would question the need to replace the rudder? Well it’s not ideal but certainly an option to free up $850 for something else. One could file the rough edges down and move on. Just make sure to thoroughly inspect the impeller, shaft, housing, cones, etc for any sign of damage. Also, inspect your Cobra Fins making sure they are straight and didn’t get bent or damaged.
it continued. we only stayed out a bit longer. I kept try and at first you wouldn’t notice, but it never really hit plane and the sound was just off and sounded wrong.
anyone have a link to pulling the pump? I believe that’s the only other thing I’m not seeing.
LINK for a 2018 SX195, should be the same.
The pump is easy to pull there are about 8 bolts you’ll need to remove, and if I remember correctly, they can all be done with a 12mm socket.
