Solas impeller
Ffemt555
Looking for input on solas impeller and one piece wear ring! Has anyone installed these on the boat and are you happy with the product?
What are you looking at gaining by replacing your impellers/wear ring? do you have current issues?
Yes i have issues and the boat as well, lol. Boat is in the shop and was told jet pump unit is loud and most likely corrosion in the 2 piece wear ring.. just looking for a better more reliable/less possibility of corrosion wear ring replacing props are optional at this point.
