Sotally Tober
- San Diego, California
- 242 Limited S E-Series
Here are my Amps:
One Arc Audio - Class H - KS 2500.1 - http://www.arcaudio.com/p/ks-2500-1?pp=24
1 Channel @ 4 ohms750 Watts
1 Channel @ 2 ohms1400 Watts
1 Channel @ 1 ohms2500 Watts
Frequency Response20Hz - 250Hz
Crossover Range30Hz - 250Hz Variable
Bass Boost+15dB @ 45Hz
S/N Ratio103dB
Input Sensitivity (Low)200mV - 3.5V
Max current draw210A @ 2600 Watts 2% THD
Idle Current1.14 Amp
One Arc Audio - Class G/H - KS600.2 - http://www.arcaudio.com/p/ks600-2?pp=24
2 Channels @ 4 ohms400 Watts
2 Channels @ 2 ohms600 Watts
1 Channel @ 4 ohms (Bridged)1200 Watts
1 Channel @ 2 ohms (bridged)Not Recommended
Frequency Response5Hz - 50kHz
Crossover Range55Hz - 5.5kHz Variable
S/N Ratio112dB
Max current draw130 Amps @ 1300 Watts 1% THD
Idle Current2.5 Amps
Fuse4 x 30 Amps
TWO Arc Audio - Class G/H - KS 300.4 - http://www.arcaudio.com/p/ks-300-4?pp=24
4 Channels @ 4 ohms90 Watts
4 Channels @ 2 ohms175 Watts
2 Channels @ 4 ohms (Bridged)350 Watts
2 Channels @ 2 ohms (Bridged)Not Recommended
Bass Boost18dB @ 45Hz
S/N Ratio95dB
Max current draw85A @ 800 Watts 1% THD
S/N Ratio103dB
S/N Ratio112dB
Fuse4 x 30 Amps
S/N Ratio95dB
