granpachuck
- Cary NC
- 242 Limited S E-Series
Thank you, I think, for the confidence to keep going. Got starboard side box out and am now using a combination of Kilmat, Noico , and some cheap memory foam . The foam is for the upper corners I am not going to be able to reach. Slow going. I don't know if I will have the energy to start the port side ...@granpachuck
It has been a few years. But from Memory the difficult part is disassembling. Not much room for movement and all hoses are kinda stuck. Reassembly went much easier. Disassembly was rough
The water box wouldn't fit out of the hatch, so I had to grind the opening a bit larger, and I think I will give it a wrap after I place it back in, but before I connect the hoses back up to it.
Our lakes here are at flood levels, so this is a good time to work on it in my driveway.
