Just had my plugs changed on the 08 sx230 and on of the new plugs blew in half the threads are still in motor but the head flew out. Any one ever seen or heard of this? Cause? I have a guy drilling the rest out just curious
He is fixing it. It was new lol I took it for one ride and after about 15 minutes it threw and over heat code and started running rough so shut her down and that's what he found today. So if he over torqued it that can make it explode?
Well, after combustion blowing out the plug, I would not expect nice clean shiny gold/silver any more. But I agree something doesn't look new about that.
On install, these are only supposed to be hand tight. If you are using a wrench you are probably torqueing too much. I have used a wrench, but when you feel the plug hit the block you need to stop immediately. Add a 1/4 turn and you are way over.
I have also heard of such a thing from undertorqueing the plugs. Gasses escape through the threads and will melt the boot (see the bottom of the boot in the photo) and separate the plug.
@Rdavis0207 ..... thank you for the post. You have sure motivated me to do some serious fact checking. I assume there is a difference between the "regular" and supercharged heads but IMO not enough to explain the difference between the spark plug spec sheet that @Beachbummer posted and the Info I have from RIVA and Yamaha. The spec sheet for my 2020 supercharged 1.8 shows a gap of 0.8 to 0.9 for spark plugs - that difference I get but RIVA Racing and Yamaha HQ both said 18 foot pounds or 25Nm of torque for the plugs - now that IS a big difference from the posted spec sheet!
@Beachbummer .... yes, figured that and I can see the plug gap being slightly different but I have to wonder about the plug torque setting I was given as it seems to be too high when compared to yours even given that there should be a higher compression involved in the supercharged engine.
I will say 18 Ft-Lbs is still a reasonably low number. I would not be surprised if that was appropriate for other engines. I was not very familiar with these troque settings until I got a torque wrench, and "wrench tight so it doesn't come of" that I would apply generally by hand before I had a wrench (and now still) feels more like 35 or 40ft-lbs. I know the number seems significantly higher, but 18Ft-Lbs is still a gentle force.
The 3/8 torque wrench doesn't even measure below 20. I have to put the adapter on the 1/4 wrench to go below 20ft-lbs.
Id also check if there is water mixed with oil. increase pressure may pop out a spark plug? But I still think its the torque that did it. Change plug and mechanic lol
Was it on cylinder [HASH=3560]#3?[/HASH] It has been known for seizing plugs. I don't know why a new plug would break other than fake ngk's, they exist, or not installed properly.
