AR 210, 2021 model. Do you know if these covers are Pry off, rotate or pull off? Don't want to break them. Thanks in advanceAnyone know how the Speaker grill removes on 2020 SX190? Snap off, pull off or rotate?
How are you finding your Polks and the amp 3 years on? Ive just ordered 4 DB652's for my 2023 SX190. I was waiting to try them on the stock stereo before buying an Amp. Could you hear the stereo at cruising speed without the amp with the DB652's? Also, did you install a house battery or is it ok with just one battery? Thanks!I replaced them with DB652's. They look way better. Once I install the amp I bought, they should push some great sound. They sound much better, even on the stock head unit.
You'll have to drill new holes to attach the Polk's. Just take your time. For the two bow speakers, test fit with lifting the hinged seats before drilling. I had to install my bow speakers higher than the factory speakers for the seats to clear when lifting because the grill was slightly bigger on the DB652's. Also, make sure they're level before installation. It's very noticeable with the grill design on the DB652's if you're not level.
When you drill the holes, make sure you run a small pilot hole with the smallest bit you have and then find a drill bit that matches the size of the screws. If you use too small of a bit, you will crack the gelcoat off of the fiberglass.
Sorry I forgot to ask did you run your ground all the way back to the battery?
Thanks for this info. Did you hook up to the original head unit or upgraded? I'm looking at a 4 channel amp but the 2023 sx190 stock unit only has 1 pair of rca outs so I think I need to use y splitter.
Thanks. How about the speaker wires. Did you have to cut them at the head unit then butt connect to the amp harness?
