Miller92063
- Omaha, Nebraska
- Limited S
Below is a list of the items I'll be installing. The amps have 4 40a fuses and the other has 2 40a fuses so my breaker closest to the battery should be around 250 correct? Then a 160amp fuse and 80a fuse close to the amps?
-Fusion 8ch 2,000w Amp to run bow, cabin, and swim deck. Open channel for mid cabin later if needed.
-Fusion 5ch 1,600w Amp to run Tower Speakers and Sub
-M3-650x RGB to replace swim deck speakers
-M3-770x RGB for Tower speakers
-Krypt tower cans.
-M3-10IB-S-GW 10" Subwoofer
-WS-420BT Wet Sounds Zone control. I will probably use the Sub line out for swim deck and use JL sub control separate.
-14g Knukoncepts speaker wire to replace ALL speaker wire
-12g Knuk speaker wire for sub
-0g Knuk power and ground run to behind the helm fuse and split to 4g.
The fusion amp will require numerous RCA splitters. Any tips for all this? the fuses are what worry me most about getting right as its been a long time since I've done a sound system. TIA!
-Krypt tower cans.
