Spectrum Colors
96Pirate
Wake Forest, NC 27587
I am planning on making a few repairs and I know a lot of you have used the spectrum paste repair kits with success. So I plan to order both the black and white. The question I have is on the white. Spectrum basically has 2 whites for my year.
Yamaha, 2004-2011, White Coat 5 CCP LVOC Color Boat Gel Coat Patch Paste Repair Kit - Spectrum Color
F557018K
Yamaha, 2006-2007, White Color Boat Gel Coat Patch Paste Repair Kit - Spectrum Color
F557017K
Does anyone know which is the correct to use? I need it for the upper deck on a '07 230. Bottom hull is clean.
I am not sure what the 5 CCP LVOC stands for on the top one. Wondering if 1 is the bottom hull and one the top hull.
Thanks all.
Can't answer all your questions @96Pirate but I think the lvoc means low volitIle organic compounds. Meaning low fumes.
wow, that's tricky. I know when I repaired my exciter, I used a basic bright white gelcoat and no one was ever able to find the repair.
I would be a bit more concerned with the newer gelcoat though.
It could be a low voc product for those nuts in California. Best bet is to call them. Update us on your findings please!
I ordered from them today, just call them and they will help you get the correct stuff
The correct one to use for an 07 AR230 would be this one.
F557018K
She said the two are different colors and that most likely the F557017K is used on a different model or the skis, though she did not specify.
It would be best to call so they can lookup your exact model to determine the correct color. Unfortunately you cannot do that on the website.
BTW...they are having a sale on the paste kits right now through iBoats.
