Sport jet 90 no crank
Teeko
Hi everyone. I've got a thundercraft typhoon with a SJ90 in it. Had a few issues with it last year and broke down and took it to a marina. They replaced the rev limiter and said it was running great. I basically picked it up and put it in storage for the winter. Pulled it out of storage yesterday, installed the battery and it cranked a few times today then nothing. It has power and when I bridge the battery to the starter, it cranks and fired up but nothing with the key. I figure I blew a fuse but I only see 2 fuses in the engine compartment. A 20A fuse near the top of the motor/by all the electronic bits and a 15A fuse that runs from the battery cutoff switch. Both are good. The manual shows a 20A fuse for the starting circuit. Is there another fuse I'm missing? If so, any ideas where it is located.
