MADYAK23
- Caldwell, NJ
- Limited S
I'm still new to jet boating and this is my second season with it, everything was done previously by the dealer as it was a new purchase last year. So I'm working on spring prep after the winter and I noticed that there is some salt buildup on the net nozzle and on the engine block after keeping the boat on land at the marina during the winter. I attached a picture of what it looks like. My question here is, what do I do to safely clean it off and what can I do to prevent it from coming back?
I was thinking of using a mixture of water and some salt away (https://www.westmarine.com/buy/west-marine--salt-off-salt-remover-with-mixer--15358591) and gently cleaning the engine block and nozzle. As far as keeping it from coming back, I was thinking about spraying the nozzle and jet housing with some silicon spray (https://www.shopyamaha.com/product/...nt-lubricant?b=Search&nw=yamaha-motor-company) but I'm not sure about what to use on the engine block.
Additionally there are several components on the exterior that require lubrication, such as the steering cables, and shift cables. What kind of lube should be used and should something like a grease gun (https://www.harborfreight.com/grease-gun-with-pistol-grip-66664.html) be used?
The manual also indicates to lube the throttle body valves but I haven't come across any instructions or information on that either.
Any help on these items would be greatly appreciated, and thank you in advance!
