RBuffordTJ
- SR
As if my own boat is not a problem right now a friend brought me his. Thought it had no spark but I verified it did.
I took a fuel sample, since both engines refuse to start......I found water. His boat sits in the lake at a covered dock. I started pumping out the gas and removed 10 gallons![Warning :warning: ⚠️](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/26a0.png)
....yes seriously...of water before I ever hit tinted liquid. I think someone hates him.
SR230 twin engine. We ordered a couple start solenoids since both click but the starboard won't turn over at all while we inspect the port.
All 4 plugs on the port engine were rusted over so after fuel was replaced with good stuff, I put in new plugs. Still won't attempt to hit, it cranks but won't start.
I want to check the fuel pressure, the pump turns on but after sitting in that much water for over a month it might have killed the pump. Is there a valve I just don't see hiding on this thing?
