Boater4468
- FSH Sport
I'm looking for any suggestions regarding the ongoing issue I continue to have with my boat. I bought the boat used with 42 HRS on it, test run very good and supposedly had no issues from previous owner.
At 50 hrs. I had a certified Yamaha dealer service the boat, everything checked out fine when they went over the entire boat.
After the service we were on the water and lost the Starboard Engine and would not restart. I took the boat back in for service and the dealer told me there were 2 defective plugs. They re-installed the plugs and said everything was fine. We took the boat out again; everything was running very well. We stopped and anchored for a couple hours of fishing, went to start the Starboard engine and it would not start after 22 tries. I limped the boat back to my lift (it took about 2 hrs.) lifted the boat out of water and flushed the engines and I started the Starboard engine with no issues. I took the boat out again and the same issue happened. Got back to my lift and the Starboard started fine again. I took the boat back to the dealer, they went over it thoroughly and said they could not replicate the issue, that everything was fine.
I was out yesterday, and the same issue happened only this time I got an engine light come on and a loud beep. I killed the power to the boat turned the batteries off reset everything and the boat started right up and ran with no issues. I stopped again same trip, and the issue happened again, loud beep engine check light. I went through the same process again and the boat started up and ran fine for 2 hrs. of trolling. I got back to my lift flushed the engines and there were no issues starting the starboard engine. The mechanic is clearly missing something, but I am at a loss since 2 times they have had it and said there is nothing they could find wrong with it.
Any suggestions would be greatly appreciated.
