v4tuna
So my one engine started misfiring would not rev past 7000 rpm. would bog then stall. It would restart but idling like a tractor. Sometimes the power would come back like an electrical short or something as it revd it would smooth out . Back on lift remove and check plugs ....I didnt have new plugs but leftovers from 3 years ago last time I changed . I had to through 4 of those old plugs till i got 4 that worked. It purred for a few minutes Great. turn off motor. Go get fishing gear to go out come back. to poor start rough idle again. I have just bought new plugs for it but suspect maybe ECU is fouling plugs . Am I missing anything If I remove ECU has anyone tried baking in the oven to dry it out before sending for repair I thinking water can cause a short to ground.
