Saltydog
- Vero Beach Florida
- SX
Backstory:
Got this 2004sx230 a couple months ago. Starts and runs good and we took it out and everything was fun. (At 1st)
Had to replace the thermostate on one side (did both) did an oil change, had to replace the depth finder with hawkeye brand, reconnected the speedo hose, cleaned some connections for horn and lights to work. And we have been able to take it out 4-5 times.
Everything I've done so far has been helped along with reading from this group. So thanks.
However, I went to take off the jet pumps this morning to check the bearings like we did when we got it (heard some noises on last trip) AND the bearing on the starboard side was one trip from complete failure! So I decided I would pull it completely out and do the rebuild on both motors and try the "oil"(set up) instead of grease. But the impeller shaft will not slide out like the port side does? Yes all bolts are out, yes I gave it some luv taps, yes i eventually broke the rubber mallet, was able to take the rear/aft bearing out and the metal race and the housing slides for and aft on the shaft - BUT the shaft splines are stuck!
Anyone ever had this happen?
