jjtherocketman
- Mims FL
- LS
Happened twice today out of the water at my house. Recently had the carbs rebuilt and tuned and after getting my boat home, I decided to crank the engines to see how they were starting. Starboard engine started up fine, but was idling at a high RPM (4-5K RPM). I tried rev'ing the throttle and it went even higher and then went Wide open. Immediately killed the ignition switch and removed the key...still running WOT. Pulled the lanyard kill switch, still WOT. Ran back to the clean out plugs compartment and opened that, still WOT. NOTHING would kill the engine! Finally pulled the choke out on that engine and it died. Waiting a few minutes, then tried it, started ok, but eventually the exact same problem happened. Nothing would kill the wide open throttle condition and kill the engine except the choke. HELP!
