Steering ratio on 2018 AR210
4x15mph
Downingtown, PA
The steering ratio requires 1+ turn of the wheel to make sharp turns and is completely different steering ratio than my prior Ls2000. Has anyone been able to change the steering ratio so the steering is more reactive and less “loose”.
All the newer boats have a "rack and pinion" ,gear ration helm. So to change it you would need to change the complete steering helm/ column. When they changed it, it was to make the steering ratio more like a standard boat
